This light blinking will take place when there is a bad cartridge or some mechanical obstructions in the carriage path. try to replace the cartridge first.
If the ring of light keeps blinking, it means that the remote controller was not connected to a receiver which is the XBox 360 console. Try to press the connect button on the console and the wireless controller to sync them together.
Hi, The standby light LED BLINK is in specific numbers, please count that how many time LED BLINKS in specific time and in specific numbers like 1 time 2 time 3 times etc, every blink has its area of fault which processing IC detects, Therefore please count and let me know the number of blinking stand by light and then i can tell you the area of fault and its solution. Hope you will understand my sayings, if need more clarification write in comments. thanks for using fixya.
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
