Canon PowerShot S2 IS Digital Camera Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error e16 on canon powershot sx120is - Canon PowerShot S2 IS Digital Camera
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Dec 02, 2016
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232935
Points
686
E16 Image sensor readout timeout error.
2 Related Answers
Anonymous
  • Posted on Dec 18, 2008
SOURCE: error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
Anonymous
  • 11967 Answers
  • Posted on Apr 25, 2011
SOURCE: What does "lens error, restart camera" message on
Try these:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2helpful
What is E16 error?
Focus is not working due to broken gear or focus motor jam.This problem can be solved in service center.
Lens error canon powershot SX120IS
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
7helpful
E16
That's probably some sort of error code your camera is displaying. I know the most common codes are E18 and E24 on canons, for the E16 try going to the following website and emailing them: www.camerasandparts.com They just work on the canons and I'm sure they've dealt with this problem before. If you end up needing to have it serviced, that site is wonderful and about half the cost of what canon charges, plus they do amazing work on these powershot cameras.
Hi We have taken around 170 photos at SX120IS
Use a card reader to download them to a folder you create on your desktop.
3helpful
Why an ei6 error msg on canona630 suddenly after just taking pix?
The E16 error is a circuit board problem and is not user fixable. It needs to go to a Canon service facility. Try to get it fixed under warranty, if possible. If not, get an estimate before repairing, as price may be prohibitive. Weigh repair costs against replacing with a new camera.
1helpful
E16 error
Hi there.
E16 Error code means (on all canon compacts) that there is something wrong with the lens mechanism and it cannot contract/extract/focus etc. Basically, if the problem is not fixed by removing the batteries for 20 minutes and reinstalling them (make sure they are fully charged) then you'll have to take it into a shop or get a friend who knows a lot about this stuff to take it apart.
Good luck and thanks for using FixYa!!
4helpful
2answers
Canon G9 has E16 error message-won't turn on
The likely has a short that is causing that E16 Error Code. Since it likely needs a part replaced, you can try this site: www.camerasandparts.com They'll fix any Powershot problem, these are the only models they work on. They are about half the price of Canon for Service and they do excellent work. They exclusively do the Canon Powershot cameras only, they're the guys if you need help with a problem on one of these cameras.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
