Anyone know why an MS outlook sync would work for the calendar and notes but not for contacts? The Hotsync logs says that everything fails...... Outlook Notes OLERR:0B-0004 OLERR:0C-000F (0x0) OLERR:0D-0003 OLERR:0D-0001 - Not Synchronized Outlook Notes synchronization failed OLERR:15-0002 OLERR:08-0001 VersaMail - Sync configured to Do Nothing Documents To Go - sync configured to Do Nothing. Outlook Calendar OLERR:0B-0004 OLERR:0C-000B (0x0) OLERR:0C-0002 (0x0) OLERR:0C-000F (0x80004005) OLERR:0D-0003 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 Outlook Contacts OLERR:0B-0004 OLERR:0C-000B (0x0) OLERR:0C-0002 (0x0) OLERR:0C-000F (0x80004005) OLERR:0D-0003 OLERR:0D-0001 - Not Synchronized Outlook Contacts synchronization failed OLERR:15-0002 OLERR:01-0001 Outlook Tasks OLERR:0B-0004 OLERR:0C-000B (0x0) OLERR:0C-0002 (0x0) OLERR:0C-000F (0x80004005) OLERR:0D-0003 OLERR:0D-0001 - Not Synchronized Outlook Tasks synchronization failed
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
