The alternator should be charging at 13.5 to 14.5vdc at the battery at engine idle. Some vortec engines had fuseable links running from the alternator.
You could have a bad ground or a cable may be shorted, a stuck relay or something not turning off and causing a drain also. You can run what is called a "parasitic draw test" to determine the source. I hope this helps.
The possibilities with an RV conversion van are numerous. There are usually all kinds of aftermarket equipment including battery isolation devices that can fail and cause the symptoms you are describing. The problem is that probably nobody can tell you exactly what to check because it would take a hands-on inspection of the vehicle to see what it is equipped with. It could be that something in the factory equipment has failed, or it could be that some of the aftermarket equipment has failed. I would recommend taking it to a local garage that is equipped to properly test your electrical systems to determine the actual cause of the problem.
Please also review this article:
What Else Could Be Wrong?
