Do you have an control board or a timer? Control board is touch panel time is a knob the you turn to start dishwasher. Most likely what is going on in you have melted wired where they connect to dishwasher.
To check/ correct
Turn dhishwasher off at breaker. Unplug dishwasher also if you can. The bottom of your dishwasher on the outside in front at bottom. There is an access panel usually requires 1/4 inch nut driver or phillips screw.driver. Remove panel. To the right side you will notice a silver square plate that has wires running into it. Remove the 1 screw usually on left with 1/4 inch nut driver. Examine the wires. Any kind of melting or scorch marks. If scorch marks are present. If you have an outlet the the dishwasher plugs into than replace cord. If its hardwaired ( ran directly from dishwasher to circuit breaker. Cut wire back make sure you dont cut too much. Remove all scorch marked wires and take off a little bit more to be safe. Reconnect wires use wire caps and electrical tape. After you finish this if the problem still persist contact a certified electrician you change the breaker and test the wiring.
If you need any further assistance please feel free to contact
