Lift the scanner lid and then open up the ADF (document feeder) mechanism off to the left.
There's a small glass under the ADF mechanism, and it needs to be cleaned.
Use a glass cleaner like Windex sprayed onto a lint free cloth to clean it.
That's it! put the ADF back down and close the scanner lid!
Problem solved!
SOURCE: black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
SOURCE: Black line while scanning and copying
Open up the document feeder and clean the scanner glass
SOURCE: 2 vertical, parallel, black, lines print on copy
Sounds like it could be bad cartridge or scanner. Try replacing cartridge first cause this is pretty easy to do and is alot cheaper.
SOURCE: when copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
SOURCE: Lines in copy print
Its not a printer Issue, but its application issue. you will need to uninstall the printer first. then get the drivers those are compatible with the operating system that you use and install those new drivers.
reboot the computer and thats all.
Problem fixed.
