Question about Pride Mobility Products Health & Beauty
I have a quantum 6000 electric chair, it will not move says battery is 100%... The only thing I can think of is one of the three lights on the bottom is now red instead of green...
  • north Jul 24, 2012
    If the lights turn from green to red then it just signifies that the chair seat is elevated and not completely down.
    Sergeant:
  • 405 Answers
HI.If the lights turn to red from green then it just signifies that the battery is busted.Is it a rechargeable battery.How long have you been using the battery?
Posted on Jul 24, 2011
SOURCE:
Quantum 600 power wheelchair. From time to time chair stops abruptly, low battery appears on controller screen even though battery is fully charged.
There is a 51 page MANUAL here:
Quantum 6000 Owner Manual
See this link for 1,500 Troubleshooting results:
quantum 6000 wheelchair troubleshooting Google Search
You may be looking at a sudden/intermittent electrical short OR one of your connectors may be loose?
http://www.thewiringbooks.com/wiring/quantum-6000z-wiring-diagram.html#gallery-1
Your chair voltage REGULATOR may also be going bad which appears to be WITHIN the "Main Brain" of your chair?
"TECO FM-50"
regulator-gkhd23p0qwnavtoilob1hbhw-1-2.jpg From the above schematic ~ there is a "Potentiometer" shown (lower left) that MAY be 'dirty' and needs a tiny squirt of "QUALITY" contact cleaner WITH SILICONE to help keep the internals clean... looks something like this (a Google Search):
I would also spray ALL of your control switches too including the inside of your joystick controls! Just a REAL QUICK squirt should do it... if it drips, you've used too much.
I hope this HELPS YOU!
Anthony
Apr 17, 2018 | Televison & Video
Where are the Quantum 600 Fuses Located?
Ron,
With a gifted power wheelchair, the usual culprit is a pair of dead batteries usually size 22NF deep cycle batteries. The pediatric chair may have U-1 (35 amp hour batteries) There are fusible links connected to both batteries at the + terminal. There are additional fuses under the rear cover in booted holders in the belly area in the rear near the controller. These power take off harnesses are fused but probably do not relate to your primary dead battery problem. Remove the front cover of the base and pull out the battery tray. Remove the batteries, test, and replace.
The owner's manual can be found here. It also includes basic service. Hope this helps.
http://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q600_series_om.pdf
Jul 22, 2016 | Quantum 6000 Power Chair - Used Electric...
When I go To move the chair comes up with error 107. , charger inhibit . I disconnected the charger. What can I do next
after do a test restart the chair. make sure both freewheel levers are locked in drive mode (hard to push), restart, make sure your connections are good, to the motors and brakes. what kind of Joystick is this?
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 07, 2016 | Quantum 6000 Power Chair - Used Electric...
It started running lower and lower even thought it was fully charged, now the last couple of day I've been getting bus overload and it will not charge
Quantum 6000 - Pride Mobility Products
www.pridemobility.com/pdf/owners.../au_q6000_om.pdf
Pride MobilityQuantum 6000 .... WELCOME to Quantum Rehab, a division of Pride Mobility Products ... The symbols below are used on the power chair to identify warnings, .... Lowpressure may result in loss of control, ... If you must stop, start up again slowly and then accelerate .... Avoid tall grass that can entangle the running gear.
[PDF]Quantum 6000Z - Pride Mobility Products
www.pridemobility.com/pdf/.../intl.../au_q6000z_om.pdf
Pride Mobilitythis power chair and must perform all of the procedures in this manual. The symbols below are used throughout this owner's manual and on the power chair to identify ... NOTE: The Quantum 6000Z and its components are not made with natural ..... Turn the adjusting screw to raise the front of the armrest or to lower the front ...
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
35 posts - ‎30 authors
Feb 05, 2016 | Quantum 6000 Power Chair - Used Electric...
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
My quantum wheel chair is stuck on charging mode but is not plugged in? how do I reset?
hi disconnect the battery terminal for 5 or 10 minutes and it might reset .......good luck
Jul 20, 2015 | Quantum 6000 Power Chair - Used Electric...
I have a quantum 6000 electric wheelchair where can i get a replacement battery charger
Gosh I am sorry but have NO knowledge Re: Quantum chair chargers but unless you got your chair and equipment from Scooter Store. which got shut down by Feds due to fraud, you might contact chair's supplier and ask about getting a replacement for your destroyed charger's source.
Failing that, does your city/county publish a "throw away" paper? Sometimes one can find powerchair's equipment posted there. That might be worth a try.
I am sorry not to be familiar with Quantum mobility aids! Anybody else, please?
Jul 09, 2014 | Pride Jazzy Select 6 Indoor Power...
Moving very slow
Hi, i seen this before, whoever fitted the batteries needs to double check the connections. One customer needed the brushes replacing so it may well be worth checking ...
Regards
Rob
www.gewizrepairs.co.uk
Mar 06, 2014 | Quantum 6000 Power Chair - Used Electric...
Charger inhibit error
Hello Debbie Waters,if you contact a Wheelchair/Scooter Repair Shop.Give them what you see as to (WHY) & ask for a price on the Part.I hope this has helped,Colin.
Jan 16, 2014 | Quantum 6000 Power Chair - Used Electric...
Health & Beauty Logo
130 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
