There is some way to change a protection (fuse?). No. The fuse usually was not broken. How long did your amp turn on?
3 seconds (DC protect) OR immediately shut down (Over Current protect)? How to confirm?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
6.Plug the amp and switch it on.
7.If your amp stays ON forever, the problem is from this long board.
8.If switch off at once, the problem is from power amp board.
Try the above- mentioned steps. I will tell you what to do next. Just search you tube for SR600 cap replacement. I have written an email here. Write an email to me if you want to fix this amp.
i have a tx-sr575 onkyo amp it shuts off as soon as u switch it on an stand by light keeps blinking .i have unplugged all the speaker connections and inputs but still the same.
I have unplugged everything as well as the AC and left it off for an hour. I tried the factory reset (hold the VCR button and press Standby). Is there a fuse inside the unit I could replace?
