If your watch keeps time for a while, then stops and starts erratically, you most likely have one of several common problems. 1. You might have a bad battery. Sounds silly, but watch batteries have a limited shelf life, and if you installed a battery that's already been in a blister pack for a few years, the battery itself could be the problem. 2. Your "set stem" is not completely pushed in. Quartz watches are designed to stop ticking when the set stem is pulled out. They'll start up again when you push the stem completely in. There's a little finger or spring-loaded prong to keep the stem in or out. Sometimes, that little prong can break off from natural use. When that happens, the stem will work itself out enough to stop the watch from ticking. Natural movement on your hand will push it back in, and the movement will take off again. Check to see that you feel a firm "click" when you push the stem all the way in. Sometimes, when changing a battery, the movement will shift inside the case just enough that the stem doesn't quite catch in the locked, "full-in" position. 3. Your battery has a bad connection. Make sure that the positive and negative terminals of the battery are in good contact with the appropriate surfaces. I have used a tiny piece of aluminum foil at times to increase pressure on the watch battery so that it makes better contact. 4. Your watch movement has dirt in it that is jamming the gears. Modern quartz watches are amazing devices--a tiny amount of force from the pulse motor operates an intricate gear system that moves all the watch hands and day/date wheels. Even a tiny speck of dust in the wrong place on a gear can gum up the works and cause a watch to start and stop. Usually this will happen at set time intervals or at the same time every day, because that's when a particular gear tooth comes into play. Closely related to this is an actual bent or broken gear tooth. Same symptoms. A watchmaker can test the gear train by placing your watch in a special testing machine that spins the gears much faster than usual. If the watch hangs up from time to time, it's suggestive of problems in the gear train. Sadly, fixing the problem by cleaning the watch may cost more than replacing the entire watch. These are the most common causes for this behavior. Hands that rub up against one another, or a defective quartz crystal are two other potential causes, but this should serve as a fairly good checklist for obvious problems. Good luck!
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
mcdevito75 here, There can be many, many reasons why a watch stops ticking, Have you wound the watch?? is the watch a Quartz?? when did you have it cleaned and oiled last?? how old is the watch??. You can try this, Reset the time on your watch, at times, pulling out the stem and moveing the hands will get a watch to start ticking again, primarily in older watches. If it"s a Quartz watch the battery may be dead. I do some work on watches and I'll be glad to look at the watch for you. Contact me at [email protected] for details.
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch). As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly. (Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually. Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops. If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out. Do not forget to rate, please.
There can be hundereds of causes why your watch isn't working properly, so, I'll not name them.
One is clear- without help of skilled watchmaker your watch will NEVER work properly.
NOTE: It may sound very strange, but mechanical watches do NOT like to be left without job.
Next time you decide to leave mechanical watch aside for long time- do not forget to wind it up once in a 2-3 days even if you are not wearing it.
This will help to prolong watch movements life and keep timekeeping steady and accurate.
