D-Link DIR-615 Wireless Router Logo
Anonymous Posted on Jul 23, 2011
Changed connection and modem to 100 Mbps. No wireless connection from router. Tried wired connection. No go. Router does connect..all lights green. Laptop sees the connection but no internet access.
Ben Darden
Level 3:
  • Master 984 Answers
  • Posted on Jul 23, 2011
Ben Darden
Master
Level 3:
Answers
984
Questions
0
Helped
313667
Points
3004
Improve the Fixya.com experience for everyone by voting!
Subject: No wireless connection from router cannot connect to the Internet.
Solutions: Straight Connection, Windows Connecter and Microsoft Fixit
Discussion: I'm going to provide you with three solutions and between them you should get online. However, you should be advised that in order to fully analyze and correct any difficulties you're having, we should be chatting or on a telephone connection. All I really know at this point is that you can't connect to the Internet through your router.
I'm going to give you three FREE general fixes and let's hope that one of them will work for you. If not, then we have to chat.
Now, let's see if I can help you.
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: [email protected].
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online.
However, if the first solution doesn't get you connected, do the following:
• Click on tools again.
• Click on 'Diagnose Connection Problems'
• and follow the instructions.
The second suggested solution is to use the Setup Wizard. It seldom works for me but you might have more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
The third solution requires an Internet connection. I'm going to pass on to you a FREE and hard to believe program from Microsoft called Microsoft Fixit! I have no idea why this little program hasn't been advertised but then I don't own their stock.
Just click on the following link and your problem should be solved: Download Microsoft's Fixit
You'll see the following areas in which Microsoft Fixit can solve software , hardware and just about every other problem you may incur. They are:
Top Solutions Windows Internet Explorer Windows Media Player
Entertainment Office Other
I suggest that you try top solutions and 'automatic' before exploring the other titles.
Be a hero and fix your friends' computers; just don't tell them how you did it! That will be our little secret.
All the best
Ben
2answers
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop,...
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to www.speedtest.net and click on one of the links on the map. This will tell you how many mbps you get to the internet.
I just upgraded to a ADSL Service 10 Mbps. - When connect either my laptop or my PC directly to the ADSL modem, all seems OK. Speed is around 10 Mbps. - When I connect them (both my computers) through...
There is no problem with your router.In fact most ISP provider sell MBPS but really does not mean you going to get 10MBPs.In your area you will share that MBPs with others.
If you need more help come back.Post / thumbs / testimonial are welcome!
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
1helpful
WRT160N Wireless Router : i just bought a new laptop and a lynsis wrt160n......
The wired and wireless speed will always be different.
The maximum wired speed will be 100 Mbps. That means the wired connection is working properly.
Wireless connection speed will depend on the router and the wireless adapter on your computer.
If you are using B-Adapter then max speed will be 11 MBPS. IF it is G-Adapter then max speed will be 54 Mbps.
The N-adapter will give you more speed.
Check in the Device manager which adapter you are using on your wireless computer.
One more thing you can try changing the wireless channel on the router.
You will need to access the router settings page.
Update the drivers of your wireless adapter on the computer.
You have WRT160N router.
This router has issues with the Firmware.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
2answers
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Connecting netgear 108 mbps super wireless adsl router
I noticed that the router i bought is a modem router and only needed an adsl line. I cannot connect the router to my broadband connection because i already have a modem from my ISP. So, i'll have to sell the router and buy a wired router without modem for me to successfully complete the installation and configuration.
Cheers!
NetGear Super G 108Mbps Wireless Firewall
If you are connecting wirelessly, then it's more than likely that your wireless card or usb dongle cannot connect as you router is probably set at 108 mbps. Your receivers are more than likely only capable of connecting at 54 mbps so change the streaming rate on your router to 54 mbps. This will not alter your internet connection speed as the 108 mbps only refers to the rate of streaming speed on your local area connection (from one pc to another)
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
