SOURCE: Just bought a Pioneer elite PRO101, pioneer elite
Check what in the HD 612 receiver what year it was made and the software,frameware version it in the programing.Do the same with the tv might not have compatible version of softwares.
SOURCE: My Pioneer 503pu/ 5030hd which
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem.
My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of
course) and found four bulged capacitors.
Many electronics companies were sold capacitors that failed in 2-5 years
instead of 10-20. The capacitors fail
prematurely due to a lack of preservatives. Unfortunately, they were installed in all
sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional 2. Open your TV and find PSB. Check
for faulty caps. If you find some (bulged
or leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself
it will save you hundreds. I have a tip/tutorial
on this site that may also help. It
gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's
called: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.
Kaufman605
SOURCE: My Pioneer 503pu/ 5030hd which comes with the 503u
Wish I knew, have one exact same trouble. Have checked all supply voltages which are correct. It appears that the screen and media Rx are not passing data after turn on, there are no transitions on any of the SDA SCL lines, all are in a high state +5V. There are transitions on them at boot up. I am using a Kworld KW-SA295-Q DE box, has a DVI-I output that provides a great picture on the monitor / screen. I believe the PC/IF board has the problem, but have not found one to substitute to test.
Also the receiver is not set to any of the default conditions.
The tuners are active but are not tuned to channel 2 the ICs not controlled by the data buss all pass signals. My thinking is that the control software has been corrupted. I found the training guide on line that has part of the procedure for upgrading the AVC System software but it is incomplete. If anyone has the info please post or send via E mail shalopt2 at juno dot com
or a known good PC/IF board that I can use for additional testing. There is no OSD as it is provided by the media RX PC/IF board.
gg
SOURCE: My 50 inch Pioneer Plasma does not have a picture.
If you don't have necessary tools and test instrument and can't
troubleshoot the unit yourself, I would advice you to look for a professional or sent it in to isolate the problem. Also, check if your unit is still under warranty/extended warranty
period, avail it because the manufacturer will fix it for free. Opening the
back cover will void the warranty. Hope I helped you. Have a nice day! Thanks for using Fixya.
This is an indication of faulty I/O circuitry in the main tuner board. This is responsible for processing the inputs (tuner, HDMI, etc) and feeds to Audio/Video IC which is in this board also. This board is repairable only at the service centers because the IC's and other parts are surface mounted and quite sensitive. I would advice you to replaced the entire board for your convenient.
SOURCE: I have a Pioneer Plasma
Please let me know what cord are you using to connect the cable box to your TV?
Jdvillanueva
