SOURCE: install CD for sj20
There is a wonderful website that provides installation CDs and Palm Desktop software for Sony Clie models that Sony no longer provides support for. I was able to get the Palm Desktop software with Clie drivers for my TJ25 from it. The website is http://www.sonyclie.org/. I'll bet they can fix you up!
SOURCE: Vista will not recognize my Clie
Please install thePalm Desktop Operating System 6.0 or higher from any search engine or Palmzone.
This will resolve the issue.
Regards
Chris 2030
SOURCE: Sony Clie PEG-N760C hot sync with Windows Vista
I had the same problems. I downloaded PalmDesktop Win62.exe update from Palm.com and it recognized my USB connection, did away with the port error and hotsynced immediately. I messed with that thing for 3 weeks before I finally tried the update. It says it's not for the peg-n760c, but it works! I don't think they want you to update, but rather buy a new pda. Good luck!
terymo2
SOURCE: My sony CLIE PEG-SJ20 is
I had the same problem with my clie peg-sj20 on my vista home basic based laptop. I could not hotsync after installing the original software. I've never tried to use my pda with this setup before so I was trying to find a way to make it work when I found this post, figured I would reply with what I found.
My Sony clie peg-sj20 runs the Palm o.s. 4.1 software and apparently Sony no longer supports this model. So after trying to hotsync and letting the Windows vista install wizard find the proper software, it suggested contacting the manufacturer of the operating system. I went to the Palm websight and downloaded the Palm o.s. 6.2 software which is compatible with vista, even though it doesn't say it supports the sj20. After installing it I performed a hotsync during setup when I was prompted to do so, and it totally worked. I'm not sure if this version works with other applications but it enabled me to hotsync running vista.
Hope this helps someone out there. Good luck.
SOURCE: I can't get the Clie PEG-SJ20 software loaded on my computer
Word is out that OS 6.01 can be installed for SJ20 to work sync in Vista even though Sony hasn't listed it as compatible.
