Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Posted on Aug 29, 2008
Phillips Magnavox 60" model ptv835
Ireplaced the chip HCNW136 for the picture shrinking and expanding offered on Magnavox help.com. The day before I replaced the chip the picture started having an upward bow at the center bottom and downward bow top center.
A
Anonymous
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Phillips magnavox P960349102 model#PTV835
If its shrinking this is and easy fix...Goto the site www.TvRepairKits.com and get there shrinking video kit for your model.
As for the colors they are likely just washed out which is due to the CRT coolant. The same site has repalcement CRT fluid for your projection TV also.
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Can You PLEASE help me
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
8helpful
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site www.TvRepairKits.com. They have a fix for the shrinking and expanding screen problem.
2answers
Magnavox 60
which chip did you replace? and what is the model number of your set?
No picture
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the video shrinking problem
1helpful
2answers
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
2answers
Picture problem
philips part# 483520988561 actual part# HCNW136 opto coupler datasheet at datasheetcatalog.com can buy many places just enter it on google.
other fixes philips part# 483520987834 actual # MC34065p and philips# 483520987712 actual# SC78104 some change all 3 and never have a problem again.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
