Gemini Sound Products Gemini CTRL-SIX USB/MIDI DJ Controller and Audio Interface Logo
Posted on Jul 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with the Gemini Sound Products Gemini CTRL-SIX USB/MIDI DJ Controller and Audio Interface It wont be detected by the computer's usb on WIndows 7
Fred Yearian
Level 3:
  • Gemini Sound... Master 5,603 Answers
  • Posted on Jul 23, 2011
Fred Yearian
Level 3:
Answers
5603
Questions
Helped
2248588
Points
16162
In the control panel, sounds and devices, check that the device is in each list under audio, voice, and hardware tabs and that your device is the default device. If NOT in the list, the CORRECT drivers are NOT installed or not properly installed.
Axiom 49 not detected by reason 5
Open preferences. Go to Control Surface tab.
Click Add. Select M-Audio as manufacturer.
Choose Axiom 49
Make sure the ports are set right.
Controls IN Port = Axiom 49 Hypercontrol In
Keyboard Port = Axiom 49 USB A In
Controls OUT Port = Axiom 49 Hypercontrol Out
if it hasn't detected yet then restart Reason.
Make sure the power on the Axiom is on.
If you still have issues the USB port on the Axiom could be bad.
2helpful
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
3helpful
2answers
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
1helpful
I recently purchased the Keystation 88es and I have installed the Able Live Lite 6 on my computer. I have installed the USB MIDI series 5.0.1 from the M-Audio website. I have plugged in the usb port as...
First step is to download Midi Monitor http://www.snoize.com/MIDIMonitor/
just to make sure you're actually getting midi over USB into the computer. This is a great utility that I use all the time for troubleshooting midi data issues.
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Try to get the keyboard to play through out my speackers
Since this has no audio output it will depend upon your computer to generate the sound using the audio system in the computer. You will need the driver software for the M-Audio to talk to the sound hardware in your computer and configure that to accept the MIDI inout from the M-Audio.
You will need to OPEN the volume and mixer controls for your sound board, unmute it, and enable the SYNTH channel and select "general MIDI".
As a test, download VanBascoe's Karaoke thing and play MIDI files to make sure your synth software is working. Then assign the MIDI source to teh USB input from the M-Audio.
1helpful
Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
4helpful
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Top Gemini Sound Products Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
