Bosch Exxcel WFX 145S Front Load Washer Logo
Posted on Jul 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fault 800 and a key displayed - Bosch Exxcel WFX 145S Front Load Washer
john
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Bosch Expert 517 Answers
  • Posted on Jan 09, 2014
 john
Bosch Expert
Level 2:
Prodigy:
Answers
517
Questions
Helped
134216
Points
901
The key is the child lock is on
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
IT-800-EC-35. How do I brighten the screen?
Adjusting Display Brightness You can use the following procedures to adjust display brightness to make it easier to
read under different lighting conditions.
Press the "Fn" key and then press the "5" key or "6" key after con? rming that "F"
is displayed in the lower right corner of the screen. Pressing the "5" key adjusts
brightness for a darker display, while pressing the "6" key adjusts brightness for a
lighter display.
In order to continue to make adjustments, press the "5" key or "6" key again after
? rst pressing the "Fn" key.
Brightness settings can also be made by navigating to the menus and tab in order of
Start ? Settings ? System ? Backlight.
The manual is here:
Casio IT 800 Series User Manual
1helpful
Paper out display in control pannel,not give test printr
prse line feed(lf) key and enter key for few second,on display gives tech access on
after that press ff key and enter key,display shows fault override on.
use your printer.......
14helpful
3answers
W200i-keypad light ok,no display light
its hardware fault i think lcd fault try to change it
2helpful
How can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
1helpful
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
1helpful
3answers
800 x 600 resolution makes desktop small with inches of black surrounding it
I have a Dell Inspiron 8100 and I believe the combination is Fn+F7 to expand the screen. Must be pressed at bootup..
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
