Samsung fridge wont start compressor right away. There is delay, so when you plug fridge in it take 15 - 20 minutes to start.To check if fan is running, you need magnet. Place it on top of door hinge. Open door and if lights are out, you are in wright spot. Take magnet of to test if lights come on. Now put magnet back and if fridge fan is running you can feel it how it blow from different outlets inside of fridge .
SOURCE: Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
SOURCE: GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser? Is the unit FULLY defrosted? Defrost fully!!!!!!
Did he check the amount of gas in the unit? If your unit has low gas...it is in need of more. R12 is expensive.
Check gas level: Shut unit for at least one hour. View compressor. Several pipes...we're looking at the largest. Start the unit. This pipe will begin to frost. If it does not clear to dry, ice or wet...stays frosted...it is low. Get the repair guy back ... but ask how much he'll charge first.
SOURCE: Frigidaire Side by Side Refrigerator/Freezer start cycle problem
check and see if fan working next to compressor
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
