SOURCE: why isn't there drain holes in bottom of
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
