It is very easy to change ink in your Epson printers. First remove the
old cartridges from your printer by following the instructions in your
printer user manual. After that, clean the printer with cleaning
cartridges. Then do a Nozzle Check and run another cleaning cycle.
Repeat the last two steps for several times until only clear fluids get
released. Now install the new ink cartridges into the printer and turn
it on and start the prime cycle.
After the completion of the prime cycle do a test print. If
everything is okay then you know that the printer is again ready for
use. It is a very simple procedure but needs concentration and proper
care. If you want a more detailed procedure then check it out at www.inkjetart.com. This site has detailed instructions on various Epson printers and matters related to it.
