Back to:
Tags:
ViewSonic VE155b  15
ViewSonic VA550 problem with horizontal blurryness (by 2 users)
posted by degofreak on Aug 29, 2008
I was given a VA550 for free. Cool huh, until I started having problems about 2 months ago. When I first hooked it up I had no problems, but recently, after the computer is turned off for any amount of time, the screen is distorted with horizontal fuzzy lines. When I use the buttons on the front of the monitor, the screen that pops up has no fuzzyness at all, but any info running to the screen from the tower has the fuzzy problem. After it warms up for a time, most of the lines clear up. I tried changing the refresh rate from 65 to 70, and that helps occasionally, but today it had no affect. After leaving the monitor and computer on for about 4 hours, it looks perfect. Any ideas?
Comment by degofreak, posted on Aug 29, 2008
"resetting the settings from the menu..." Resetting the refresh rate? The resolution? Which menu? Your answer is somewhat ambiguous... It doesnt have anything to do with the sharpness or brightness because it works well with the setting options on the monitor itself, just not with any info sent from the cpu.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Sep 10, 2008
Yes, I have the same problem...fuzzy horizontal lines. The monitor, itself on screen adjustment display does not show these fuzzy horizontal lines. Only information coming from the PC shows these lines. Of course, I tried a different PC and a different VGA cable. The problem appears to be in the video circuit of the VA55O. I also substituted the external power pack. I still have the same symptoms. I am hoping someone might be able to tell us it is some bad electrolytic cap on the circuit board. Thanks in advance for any suggestions.
Best Solution
Thanks for Trying (70)
dileep007
Rank:Wiz Wiz
Rating: 85%, 559 votes
try resetting the settings from the menu ....
if the sharpness or the brightness is high you may feel fuzzyness ..
and also just have a check is there any magnetic field placed near by the monitor if so take it some what away and then give deguass option ....
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Rating Locked! (?) degofreak has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ViewSonic VA550 problem with horizontal blurryness:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
I have not power, no power light,just a ticking sound...
Monitors
Is this a defect or something that can be done to correct?...
Monitors
Cant fix or reset to 1680x1050
ViewSonic VE155b (Black) 15" LCD Monitor
trying to convert my t860 monitor into a TV monitor by...
Hello, Every time I hit a key to get the monitor out of...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
