SOURCE: Panasonic KX-TG1033 suddenly stopped working.
I just found this on another board, and it did work
One disappointing problem with this phone that I discovered only 74 days after purchasing the system: The base units "decides" for some strange reason "to go on a strike" and stop responding. This problem is documented on Panasonic's web site and is solve-able by simply disconnecting power from the base unit and re-connecting it. This works, but somewhat lowers the confidence in the "perfectness" of this product.
SOURCE: Dialling Tone
HELLO . AM JAMAL FROM SYRIA , I VE THE SAME PROBLEM WITH THREE PREVIOUSLY USED XALIO 300 WHICH I BOUGHT FROM SOME BLACK MARKET. I SUGGEST U TO INSERT THE CODE ACCORDING TO UR COUNTRY , FOR EXAMPLE :
PRESS FIRST " R " BUTTON THEN 99 THEN " RC " CODE WRITTEN UNDER BASE UNIT THEN " R " OR " PAGING " AT THE LOW RIGHT CORNER OF HANDSET .
SOURCE: Panasonic KX-TGA711E (4 handsets) cordless phone no dialling tone
I unplugged the phone and then plugged it back in!
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
