Posted on Oct 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a pair of Technics SL-1200MK@ Turntables and I blew the fuses on the curcuit boards. I'm having trouble finding a discontinued fuse. If you know anyone selling them, please post some links for me. My tables are useless without them. here are the fuses I need A.S.A.P....... 250V. T250mA FUSE (INTL-220V) and 125V, 1.2A FUSE (USA)
Grubhead
Level 3:
  • Audio Player... Master 5,755 Answers
  • Posted on Oct 10, 2017
 Grubhead
Level 3:
Answers
5755
Questions
Helped
1662073
Points
11417
Any decent electrical shop should have those fuses. They tend to come in 20mm and 30mm lengths. You will need to know which. Also there are fast blow and slow blow fuses. If you have the originals and you can see the remains of a coil then you want slow blow. Otherwise just replace them with fast ones. The 1.2 amp fuse can be replaced with a 250 volt fuse.
So you want a 250ma 250v fuse.
and a 1.2A 250v fuse.
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Dec 08, 2007
SOURCE: 6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Anonymous
  • Posted on Jan 11, 2008
SOURCE: 6.3 slow-blow fuse
This worked for me. My set has a little panel around the power cord with a single screw; the real trick is fitting my hand in there to change the fuse. I guess they make the opening for monkeys or small children or something.
Anonymous
  • 41 Answers
  • Posted on Apr 19, 2009
SOURCE: Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Anonymous
  • Posted on May 08, 2009
SOURCE: i can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
skistockli
My2CentsWorth
  • 73 Answers
  • Posted on Jul 11, 2009
SOURCE: I need help finding a fuse for my HP PL4260N
You will be lucky if its actually the fuse. This HP TV is known for a circut board problem that was actually A KNOWN PROBLEM and HP still sold the TV's anyway. They were fixing the TV's for Free up until Dec when they decided to stop. You might want to contact the group that is taking legal action agaist HP for Selling a known defective product.
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Won't turn on
Check the fuse in the plug. If that's ok then the fuse on the board might of gone. & if that's ok as well then the trancformer has gone bang.
1helpful
My technics 1200 mk5 is blowing a 125V 250 mA fuse on the board just after the transformer
There must be a shorted power transistor in the power supply area. Check the voltage output of the transistor to determine which part is having a short circuit.
1helpful
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
1helpful
2answers
No lights or responce (power issue)
If you do not see fuses on the smaller pc board, next to the main PC board, underneath the turntable platter, then you don't have any. Not all 1200s series turntables have these fuses. So, that means you more than likely blew the Technics power supply / transformer.
Not an easy fix, and I don't recommend you do this, as seeing how you did not replace the pop-up light correctly, it seems you lack the experience. When you saw that spark, that means that you did not shield the pop-up light wires properly, a big mistake. It more than likely touched the cabinet, and created a short - very common. This short is enough to take out he power supply.
You will have to take your unit to an authorized repair center for repair.
Good Luck!
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
Screws to secure spindle to Technics 1200Mk II chassis
hi its called the N2 screw,, get it here, for next to nothing!
Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Repairs
Technics parts are discontinued, so it will be very hard to find a service center who will take in these units for repairs. Sorry.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
SL-1200MK2 Balance weight releasing?
Honestly... Just Pull it back off and switch it around.... it may feel like your gonna break your tone arm but just pull at the weight and it will give before your tone arm does... but BE CAREFUL!!!
 Grubhead
Grubhead
SmartAviator
SmartAviator
