Hi Cheryl,
to do that open the freezer door,remove kick(toe)plate, on the left side under the hinge you will see a plastic union coupling the tube from the resevior to the tube inside of the door unscrew that union and pull the tubing apart. BE PREPARED for some water in the tubing to come out onto the floor and possibly all the water in the resevior may also come out ontothe floor so have a few towels ready
I see the coupling, it has three sections. Which sections unscrew? It nit coming apart easily and u want to be sure that I am disconnecting the correct sections and not
simply breaking the plastic.
the section on the left is the one you should disconnect, unscrew it in a counterclock wise direction while holding the center section, it should not so tight that any tools are required but it should come apart fairly easy(will be snug at first then loosen) you can use pliers if necessary
