Thanks for the update, regarding the thermostat.Hope replacing the thermostat resolves the problem.Keep updated.Thanks.Helpmech.
Hi.Does the new thermostat has the same rating with the old one?
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Here is the pdf document for the Filtrete thermostat. The wiring diagrams start on page 7: http://www.google.com/url?sa=t&sourc...
This web address is for the Carrier therm: www.favret.com/pdf_files/thermostats/tp_prh_3si_install.pdf
Page 15 has the wire coding for the Carrier.
You should be able to check for correct wiring with these 2 documents.
If you still have a problem getting the AC to work once you check the wiring, please reply back and we will look further into it.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Andie
I think the model number of the Filtrete therm is 3M-30. The old Carrier therm is A07049. I think the Ac is 2 speed, but I'm not sure.
I discovered on my own that the Filtrete thermostat is not compatible with the Carrier control module on the furnace. I have just ordered another Carrier thermostat.
The information from the experts was not helpful. They only sent .pdf files of the documentation I already had.
I discovered on my own that the Filtrete thermostat is not compatible with the Carrier control module on the furnace. I have just ordered another Carrier thermostat. The .pdf files sent were of documentation I already had.
