Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
Danny Thomas Posted on Jul 22, 2011
20 hp intek will only run as long as pour gas in carb, tried 2 other carbs, with same result.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
105
Points
Hi there it seems as if you have a blocked fuel delivery line, take a look at the supply by means of elimination first take of the pipe going to carb from tank and see if there is a supply of fuel, if not take of the tap at tank side of fuel pipe be sure to part empty the fuel tank first then inspect the taps filter give a good clean with a air line make sure you blow through the whole tap as well as the filter, this should help your problem and get you running again.
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
1helpful
2answers
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
3helpful
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
2helpful
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
2helpful
Carftsman DYT 4000 42" 18.5 OHV Intek Plus Fuel Problem
Sounds like you have a float problem their is a needle and seat the lets gas into bowl of carburetor if its bad it will not stop letting fuel in the carburetor causing your problem (Be sure to change oil before ing engine over or you could damage engine (with this problem you get gas into case which will remove oil from engine parts inside !
Top Briggs Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
