Computers & Internet Logo
Posted on Jul 22, 2011
Hi,i am having edimax br-6204 wlg wireless router and i am facing problem sometimes RTD reaches more than 2000ms & getting request timed out in between.I am suspecting WAN port speed is not matching with ISP Switch port speed. My question is how to identify WAN port speed of edimax and if need be how to change the speed. If this is not the cause for my problem,do you have any other thoughts to rectify this issue. Thanks.
Ali Reza
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Jul 22, 2011
Ali Reza
Contributor
Level 1:
New Friend:
Answers
38
Questions
Helped
5591
Points
92
Hi best is to choose 100 full duplex you may find this setting in web base router page by typing 192.168.1.1 username admin and password 1234 this is default if you not changed it find WAN setting if there is option you can change it to 100 Full duplex most of the Routers has auto sense features than can do for you should you need any help please contact me http://computernetworksupportindubai.com/
How can i change the SSID on my EDIMAX router BR-6428nS
Please download your router's user manual from here, and see page 45; there you will find your solution for change SSID of your Wireless network.
http://www.edimax.com/images/Image/manual/Wireless/BR-6428nS/BR-6428nS_Manual.pdf
Cannot connect my wifi, edimax br-6225n to my Cellphone medias n-04c
Here is the manual for the router and how to set up the router t the Internet.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/BR-6226n/BR-6225N_Manual.zip
The Cellphone is capable of using 802.11b/g/n. So it should be capable of being set-up on Wi-Fi to use the router, as long as you set up the correct SSIS and password for the router.
Here is the manual https://www.nttdocomo.co.jp/english/binary/pdf/support/trouble/manual/download/N-04C_E_All.pdf
My edimax br 6428ns keep on losing its internet connection...i have an internat connection around 30 min but it will stop and i need to run the setup again in order for it to work..
Check the connection type is not "Connect on Demand".
Check the Idle Time Out setting is not used.
This specifies the amount of time the router waits before shutting down an idle connection. This option is only available when "Connect on Demand" is selected. See the manual
See
http://www.edimax.co.uk/edimax/download/download/data/edimax/uk/download/for_home/home_legacy_products/home_legacy_wireless_routers/br-6428ns
Edimax BR-6226n nLite Wireless Broadband Router
Hi!
How can we assist you with your router? Please Keep in touch. Cheers!
How to put password?
Click here to visit official Edimax site for Edimax BR-6226n details and go to download area. Get the Quick Install Guide and refer to 3-4 Wireless Setup Page 20 for detailed instructions.
CreativeTECH
1helpful
Asks for IP address and password
Try reading the Quick Installationguide and see of that helps.
http://www.edimax.com/images/Image/QIG/Wireless/BR-6204Wg/BR-XXXX_QIG.zip
1helpful
3answers
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Top Edimax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
