Question about Casio Waveceptor Atomic VQ200HA 1AV watch
I have a Casio waveceptor 4305. Since having the battery changed I am running approx 2 hours ahead. I can manually set the time and date but cant move the minute and hour hand.
    President:
  • 2,501 Answers
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Jul 23, 2011
SOURCE:
My casio 4305 watch is showing the wrong time and ive been through the instructions but its still 3 and half hrs fast
You need to reste youre watch.
you need te set the dail to 12 hour position.
Doing it by holding the a and b button together. wait about 5 second and the dials should shift to 12 o clock position.
If not use the B button to shift the secons hand, then a then b fot the minute hand, then a en then b button to shift the hour hand.
After placing all the hands on 12 you press b on time and yourewatch sjould then adjust to the right time.
May 12, 2011 | Casio Waveceptor Atomic VQ200HA 1AV watch
Times showing wrong on my casio 4305 model?
Note the four-digit module number from the watch back, and go to this link for full info in PDF format:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
Aug 15, 2010 | Casio Waveceptor Atomic VQ200HA 1AV watch
How can i adjust the date on my casio waveceptor wvq-550 watch
http://waveceptor.casio.com/support/manual/ is the link for the official manual, but I thought this one just updated to the atomic clock? it's supposed to connect every 4 hours and update itself.
Jun 16, 2010 | Casio Executive Wave WVQ550DA 1AV Watch
Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
Feb 05, 2010 | Casio Watches
Casio 4305 battery change problem
You don't say whether it has the minutes right and the hour wrong or if both are wrong. If it's just that the hour is wrong, you need to set the time zone.
Atomic clocks and watches have a "zero" position. Your manual should tell you how to "zero" the watch and what the time should be when it is zeroed. Each manufacturer is different. I have one that points to 3:00 and one that points to 12:00. If you zero your watch and it doesn't point to the right position, you will need to remove the movement from the case and manually move the hands to the zero position.
Been there, done that.
Jun 13, 2009 | Casio Waveceptor Atomic VQ200HA 1AV watch
Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio 4305 battery removal and replacement can't see how to release the old battery cr1620
just get a pin and put it down the silver bit with a small black bit in the middle then leaver the pin just a bit in the direction of the centre of the battery.
Apr 07, 2009 | Casio Waveceptor Atomic VQ200HA 1AV watch
Need maual to set the correct time and everything else
Follow this link:
Rate, please.
Apr 01, 2009 | Casio WVQ140EA 7B Waveceptor Watch/Metal...
Had battery changed how do i reset time and date
Visit: www.casio.com/products/Timepiece/ - 20k - Cached - Similar pages
Try to find manual here.
Dec 21, 2008 | Casio Atomic Timekeeping Waveceptor Watch...
Casio Waveceptor Atomic VQ200HA 1AV watch Logo
512 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
