I'm trying to adjust the picture as well but my picture is too tall so I lose video on the top and bottom. I do not have a manual and cannot find the picture setting item on the menus! I need step by step instructions!! Thank you!
You can't post conmments that contain an email address.
<p>There
are two prevalent formats for video programming: full screen and wide
screen. LCD TVs are designed to show a wide screen picture to go with
high-definition (HD) programming. When standard-definition (SD)
programming is watched on an LCD HDTV in its default settings mode,
there will be two vertical lines on the right and left sides of the
picture. You need to go into your TV settings menu to troubleshoot this
issue.<br />
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
<span><br /></span>
<span>Instructions</span>
<ol>
<li>
Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br />
</li>
<li>
Select "View" from the list of options.<br />
</li>
<li>
Choose
a viewing mode that will eliminate the vertical lines. Select "Zoom" to
crop the on-screen image to fit the screen. Select "Wide/Widescreen" to
stretch the on-screen image to fit the screen, or select
"Panoramic/Panorama" to stretch the sides of the onscreen image to fit
the screen (recommended).<br />
</li></ol>
Im Pretty sure in the menu screen there is an adjustment, That is assuming that the picture is adjusted to far to the left, Go to a Tv guide channel and try reading, See if you can read the complete listings?
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2) Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD By dmorrow54 on Nov 13, 2007 Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me. Add a comment
c7carl
5 minutes ago
WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use. Comment:
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature. 4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically. 4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size. 4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position. 4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position. 4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control. 4.14.2 Viewing Modes Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3). Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom. Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles. Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode will return to widescreen.
