The LED light bulbs operate at 3 to 5 V usually. The noise your hearing is a result of the voltage reduction within the internal workings of the lamp base. The lamps should be installed with an
LED driver vs a transformer power supply.
This is usually on most packaging:
LED MR16 lamps operate in the same fittings as regular 12V lamps. However, they work best when they are mated with an led driver in place of the transformer.
Example of an LED driver:
http://www.google.com/products/catalog?hl=en&safe=off&rls=com.microsoft:en-ph&q=LED+Driver&um=1&ie=UTF-8&tbm=shop&cid=16162019396751156854&sa=X&ei=HzQpTqOWOK_NmAX0-LWqDA&ved=0CEcQ8wIwAg#
The noise will not go away unless you use an LED driver with the MR16 lamps.
Thanks for choosing FixYa.
Kelly
