Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dont know what is going on with my camera, but i i charged the battery and now it wont turn on. i dont think i over charged the batt. because it wasnt on for that long. PLEASE RESPOND SOON i have a family trip to go on and i wanna be able to take pics with them !!
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Jul 22, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
960035
Points
10121
Rechargeable batteries can and do just die without warning.Sometimes the charger does so as well. The charger automatically prevents overcharging though.
Realistically, all you can do at short notice is to try another freshly charged NB-6L battery. if a camera shop has a display model they might allow you to try their battery in your camera, or more likely, your freshly charged battery in their camera.
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
3helpful
WHEN I WANT TAKE A PICTURE, MY CAMERA TURN OFF, AND DONT SAVE NOTHING?
It sounds to me that you're using the wrong kind of batt. or there is something preventing the batt. from working correctly.
It requires quite a lot of batt to generate a picture, so please follow these steps.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Brand new battery camera still wont charge
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or a cable exchange.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Kodak 8.2 will not turn on i've only had the camera for a couple of months . I have charges the camera for a day or two and it still will not come on
I think you mean the camera and not the ESS software. Since you have only noted the kond of the software and not the model of the camera I have written 2 possible solutions for you:
I hope this will help:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
Contact KODAK:
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
The lens wont go in and when i turn on the camera, it dies within seconds. how do i get it to work again?
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Wont turn on anymore. shutter goes in and out and screen wont turn on
Remove the battery
Contact KODAK:
2helpful
2answers
I can not turn on my camera. I think it has something to do with the lens because I can still look at my pictures under favorites but when I try to take a picture the lens comes out then goes back in and...
This is a common issue w/ the Kodak M-series camera which Favorites can access to view pics but wont turn on or take pic.
Here are the steps:
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
2answers
My kodak digital camera wont stay on!
Your problem could be the result of corrosion on the battery terminals inside the camera. Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, clean both ends of each battery, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
2answers
Battery pack
I don't know if this will work but it worked for my PowerShot A300.
Take a pencil eraser and clean the battery connections inside your camera. Just be sure not to let any eraser flakes inside the camera.
The Canon rep indicated it would work for the A300 ... Not sure why it wouldn't work with yours as well.
Good luck.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
