Ninja Saga Logo
Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One hit kill - Ninja Saga
rey francis basa
Level 3:
Guru:
  • Master 666 Answers
  • Posted on Jul 22, 2011
rey francis basa
Master
Level 3:
Guru:
Answers
666
Questions
0
Helped
174814
Points
2163
You like Ninja Saga and you like to rule? This site is the place for you. http://fbcheater.blogspot.com/2010/03/ninja-saga-one-hit-kill-cheat.html.
It is he place to get facebook cheats and walkthroughs.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment in return. Have a good one!
deredderek9090
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Ninja Saga Expert 79 Answers
  • Posted on Dec 07, 2018
deredderek9090
Ninja Saga Expert
Level 2:
New Friend:
Greenhorn:
Answers
79
Questions
0
Helped
49067
Points
224
Customer care support service number +1--833^^272_{0777},,,,,,,,,,,,call THEM
Waverunner does not stop with kill switch
The switch suppose to ground the coil for the spark plugs, try to remove the kill switch and verify the continuity of the switch contacts.
Jul 04, 2014 • Boating
My vtx1800c motorcycle may or may not turn on when I hit the ingintion
...... and when you put the kill switch into the run position, did things return to normal?
Mar 07, 2013 • Motorcycles
MY SKIDOO WAS RUNNING I HIT THE KILL SWITCH AND NOW IT WONT START AND HAS NO SPARK WHAT SHOULD I DO
On most of the ones I've seen the kill switch just grounds out the spark, killing the engine. Make sure that for some reason the kill switch isant remaining grounded out.
Jan 03, 2013 • Motorcycles
2answers
How do u kill gannondorlf
First part: Defelct his energy at him and hit him with the master sword. part two: Use big sword and naruys love
1helpful
2answers
How to cheat one kill dead
One Hit Kill Cheat? I have it. You need to have cheat engine though but if you don't have it, I included a link on this URL for you to download cheat engine and load One Hit Kill Cheat.
Please let me know if it helped by selecting YES. Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 31, 2011 • Ninja Saga
2answers
How do i start my toyota camry after i have hit the kill switch?
I guess you tried reversing the kill switch. But did you try it after you put the ignition on? Some switches work this way. Try different things. ignition on, ignition off, etc
My 50cc scooter had problems starting this summer after I hit the kill switch. Then battery ran down with me trying to start it. Shop fixed it-said it was carborator, but the next day made similar ''I...
No it's not normal. According to your description, you may have a grounding kill switch. It's not common, but may be so. Disconnect the switch completely (underneath the plastics) and see if this helps, our replace it. It may be something else, just perceived as a coincidental switch problem
Poulan chain saw 295 pro.
Hi pietras 1,
My name is Dennis and I would like to help but what I think may be a problem, has to be confirmed visually, so I can only give you a guess where I'm going with this. The kill switch is a ground wire for the ignition so the magneto current will not jump the gap at the plug. If the ground wire is disconnected from the kill switch the ignition will not be grounded out then you request it to be grounded. Now if this wire that is disconnected is entangled with the rod that connects the throttle to the carburetor that could be the reasonthe machine is a run-away. Look at the linkages in the area ofthe kill switch and see if this makes sense.
Please rate the solution because I depend on you for your rating to help me learn toassist correctly.
Nov 02, 2008 • Garden
Top Ninja Saga Facebook Apps Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Ninja Saga Facebook App Expert? Answer questions, earn points and help others
