Make sure the batteries' voltage are exactly the same as the batteries you replaced. If you are still having the same issue even if the batteries' voltage are the same, update me with the brand and model of your machine.
had same problem last week, get a faint display of partial figures for about 10 seconds which then gradually fades to nothing. Backlight is now staying on permanently. for outside and inside units did the "remove batteries for 48 hours" and new batteries of course. did you find a solution?
weak battery, or loosen display.....
change battery.... if doesn't help,. open device and check screews that are holding display, if it's loosen, tight it up
Run the software calibration for easy troubleshooting, and fix it. However adjust the REED switch, clean it, and tight all plug or connector very well. Please read you instr. manual or download from www.iconservice.com God bless you
It sounds like a short circuit somewhere in the watch. A visit to the authorised dealer sound necessary.
To find your nearest dealer go to "casio.com" click on "support" , then from the menu on the left, click on "repair and service" to find your dealer or service center.
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
You have to replace the battery with the new one. In most cases underpowered battery causes faded or even disappearing digits on LCD unless your watch has been damaged by water. Find your nearest watch repair shop or do it yourself.
Do not forget to rate, please.
The blinking asterik means low battery. Could be that your replacement batteries aren't full power.
What is really sounds like is a static charge problem though. If you don't have anything stored in memory that you are worried about losing, try taking the batteries out for a full 24 hours. This will let the capacitor drain and performs a static discharge. After 24 hours put working batteries back in.
way to do it > insert stylus in left bottom corner of ur phone but before it take back up or consult service centre coz might be display issue good luck
