I have a problem with a card reader A-data 52 in 1 and the RS-DV-MMC for my 6630. When I try to transfer files on it an error message apears : Cannot copy: The disk is write protected. Remove the write protection or use another card... I tried to format the card from the phone... no result - the same problem. I tried to format it from the card reader but it's write-protected and windows doesn't allow me to do that. Just help me :) There's no use of that card reader if I can only copy files from my cellphone. Please help me... the disk is write-protected remove the write protection or use another disk
When i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
I have a problem with a card reader A-data 52 in 1 and the RS-DV-MMC for my 6630. When I try to transfer files on it an error message apears : Cannot copy: The disk is write protected. Remove the write protection or use another card... I tried to format the card from the phone... no result - the same problem. I tried to format it from the card reader but it's write-protected and windows doesn't allow me to do that. Just help me :) There's no use of that card reader if I can only copy files from my cellphone. Please help me...the disk is write-protected remove the write protection or use another disk
Just place tape on the first pin from the tapered side of your mmc and the write protectin error will be gone
[email protected]
I have a problem with a sd memory card.When I try to transfer files on it an error message apears : Cannot copy: The disk is write protected. Remove the write protection or use another card... plz give proper ans.to remove this problem
First time u should unlock the memory card with the UNLOCK SDIMMC_MEDICAL CARD. all data containing inside is loose. backup all data before using the device data cable or using bluetooth device.
step1. insert mmc into device wait 10 seconds, red light in device in on, step2. put mmc into your phone and format mmc....and mmc can using as usual.
before you can do all the step, remind the password u put to lock the mmc, if u forget the pass let go to the stp in top. device price in indonesia us$3,5(jakarta)
nb. dont worry if the phone say your mmc is broken just formatted.any problems meet me at ym: [email protected].
I have a problem with a card reader A-data 52 in 1 and the RS-DV-MMC for my 6630. When I try to transfer files on it an error message apears : Cannot copy: The disk is write protected. Remove the write protection or use another card... I tried to format the card from the computer but not format the computer
I have a problem with a sd memory card.When I try to transfer files on it an error message apears : Cannot copy: The disk is write protected. Remove the write protection or use another card... i using nokia 6260.
nokia 6600 memory card
I am able to format my memory card from my pc. But now when I add any file or folder, it says write protected
how to solve this prob?????
when ever im trying to delete files from my memory card using card reader its popping up message as"disk is write protected or use another disk"
how to remove write protected kingston memory card of nokia 3230
I have a problem with my Nokia 3230 memory card. When I try to transfer files from computer to memory card it cannot copy. The message shows "The disk is write protected". Please help me to solve this problem
