Question about Jugs Baseball 101 Pitching Machine
Jugs 101 pitching machine , bottom motor will not run ,no current at connector on circuit board
Just had this happen on my machine. Opened up the control box and found center disc capcitor was loose from cold solder joint. However we also found the hot lead for the motor at the wiring block on the circuit board had a cracked solder joint. Simply reheated with solder iron and applied little extra solder and it working again.
Posted on Oct 10, 2012
SOURCE:
Power shuts off when i turn on switch
There can be two possible reasons for this to occur. The first would be that the pitching machine might need more power than that which is available at home, or the machine might be working for a long time and may have got heated up.
Jun 19, 2014 | Jugs Small Ball Pitching Machine
Hat is the max speed for a Jugs MVP
I think it's 70 mph not positive but pretty sure
May 06, 2014 | Jugs Mvp Pitching Machine
How to remove wheel from jugs pitching machine
Pretty sure you can take it to a tire shop and get that done
Apr 02, 2014 | Jugs Small Ball Pitching Machine
Blowing fuse on small ball pitching machine
Are you using the right size fuse I would call jugs and ask them what fuse it takes you could also have a wire that's exposed and touching something metal look for that too
Mar 09, 2014 | Jugs Small Ball Pitching Machine
My AQGMD149 washer-dryer has a fault code F 1 and says the machine is blocked
The fault code F1 (or F01) is a Motor/triac fault. The triac is a device for controlling the relatively high currents required by the washing machine motor from the low power chips etc on the main Printed Circuit Board (PCB). Either the motor or triac has a short circuit condition. Check connectors on motor and main PCB card making sure they are sound and not lose. If the connectors are ok I would replace the triac or power board.
Jan 11, 2014 | Ariston Technologies AWD 129 NA Washer/...
Fix jugs pitching machine wheel
What's wrong with it need more info
Mar 31, 2012 | Jugs Small Ball Pitching Machine
When in operation the machine itself is out of balance.
pull off the wheel and run the machine. you will be able to see if the hub is out off balance. if it spins true the you have a rim or tire out. this can be fixed by having a tire shop balance it for you or call Jugs and get a complete replacement,tire and rim ,shipped mounted and balanced.
it is very unlikely that the motor shaft is damaged unless it was droped trying to load it into a truck.
it most like;y is the tire and rim that is out
Nov 29, 2010 | Jugs Small Ball Pitching Machine
My jugs pitching machine is making a rattling noice in the motor area
It could possibly be one of the bearings starting to go, is the machine well used or new?
Oct 27, 2010 | Jugs Small Ball Pitching Machine
Jugs Baseball 101 Pitching Machine Logo
666 people viewed this question
Top Jugs Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Jugs Sport and Outdoor - Other Expert? Answer questions, earn points and help others
