Hi Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows on the to scroll up until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the open the steam knob again. Let it quit on its own. Refill tank again and prime the machine and your ready. Exit "Descale mode and scroll down to "Reset descale", press the enter button and chose "Yes", then exit and your ready for the next time.
Marion, mine does the same and is around the same age. Did you ever get advice regarding this. I don't use rain water, I use tap water, but same problem
