Question about Kenmore Heating & Cooling
Kenmore portable air conditioner Model 484.35338 serial no AP0000320252 made in spain code X5RKMFE709/01 quit running after 4hrs run. DRAIN WATER light is on. How is the water drained?
    Brigadier General:
  • 4,736 Answers
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan that can hold a least a quart of water. Or roll it to an area, where you can allow it to just drain. If you drain it in place into a pan, be sure to turn the unit OFF & unplug it, before draining the water.
If you have misplaced your Owner's Manual, you can get one online from Sears Parts Direct.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 21, 2011
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Why does my a kenmore portable air conditioner tell me to empty the tank. I can't find any "tank/bucket" to empty.
Should e a drain on the back o f the unit to drain condensate water off. It will not run until yo empty it.
Jul 21, 2016 | Kenmore Heating & Cooling
P-1 code
Hello Friend, thank you for allowing me to assist you!
If you are getting an error code P1 on your Frigidaire air conditioner, normally it indicates that the bottom tray is full. Carefully remove your air conditioner to a drain location and remove the bottom drain plug and allow the water drain. Then restart your appliance and P1 symbol should disappear after you have let your appliance run. However, if the error code continues, at this point, I would recommend reaching out to a professional to proceed further. - Z
Jul 20, 2014 | Frigidaire FAP094P1Z Portable Air...
I have a Kenmore C120 portable air conditioner. It is leaking water from the back bottom. There is a white drain but this unit is supposed to self evaporate. At least it did last year. Now it is leaking...
Interestingly, your Kenmore Portable AC is manufactured by Delonghi. Occasionally, what you are experiencing happens when the humidity level is high and the air intake filter needs to be cleaned.
That also means that you will need to drain the tank, at least once.
You know where the drain plug is, so you can either carefully take it outside to drain or put a low sided container, capable of holding 1 1/2 quarts of water under the drain plug. If you drain it inside, turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to drain it.
Hope this helped you to solve the problem.
Jul 13, 2011 | Heating & Cooling
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Water is spilling out of the back of the unit.
the only thing to do is put the unit in a permanent place and run a drain some where.
Jul 17, 2010 | Maytag M6P09S2ACOM Air Conditioner
Boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Aug 24, 2009 | Heating & Cooling
Tank full after 5 hrs of use.
The amount of water (condensate) that your unit produces is directly related to the setting you have the unit set to and the relative humidity of the air/
That being said it has been a much more humid summer this year almost everywhere, so I'd venture a guess that your A/C is working very well, based on the extra moisture (condensate) that it is pulling out of the air.
A/C and Dehumidifiers both tend to run longer and produce more condensate when having to deal with excessive humidity. But, that's what these machines were designed to do - extract moisture from the air where they are placed to keep us cool and dry feeling!
Enjoy the cool air and remember, Winter is coming!
Hope you find this Very Helpful and best regards!
Aug 24, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Maytag portable air conditioner runs for 2-3 seconds then stops and shows code "E1" on the display
empty water & clean filter.. full water drain (which takes a few weeks to fill) will shut off the unit
Jun 08, 2008 | Maytag Heating & Cooling
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
588 people viewed this question
Top Kenmore Heating & Cooling Experts
1STHVACMAN
Bill Long
Jay Finke
Jay Finke
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
