Question about Freezers
Dandy 8.8 fridge not working but freezer does
Freezer is nice and cold but the fridge doesn't work at all. I think the unit is only a few years old...Any suggestions? My fridge freezer got very frosted up, so I defrosted it yesterday; it seemed okay when i turned it back on; made noises and began freezing again. The outside of the unit was hot.  But after a couple of hours the fridge was warm again - any ideas?
  • daniellerose Aug 29, 2008
    freezer works but fridge stop cooling
Freezer works but fridge wont cool
Posted on Aug 29, 2008
SOURCE:
I have a Maytag 3 door ,freezer on the bottom, for the last 3 years every few weeks the fridge looses its coldness and the freezer is ice cold also it it always on temperature 1, so I have to unplug it...
Either, the defrost timmer has had it, or the freezer defrost element has failed, the element is the most common cause of this type of problem. You have ice build-up in the freezer cores because it cant defrost, all frostfree units rely on cold air from the freezer to blow into the fridge, if the freezer cores become blocked, air can not pass to the fridge side. I bet you, if you left the unit off for 2 days to defrost totally,,,,with the doors open...then plugged it back in, it would work like new for 2 weeks.
Timmer or defrost element needs to be replaced...do not fall for the trick that the fridge mech. has to take it away, you tell him that this is the problem and you will save yourself ALOT of cash.
Dont forget to vote for the solution...regards Russ
Mar 08, 2011 | Maytag Freezer MQC2257BE
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
331 people viewed this question
Top Freezers Experts
Dennis Boxerman
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
