1.Turn the printer off.2.Open Front cover.3.Press and hold X button.4.Relese X when the ! LED is illuminated. Note:Be patient as the LEDs will light up in multiple patterns before finaly stopping at !.5.Close front cover. Note:Observe that green button and 3 other LED will be illuminated at the same time.This is Home position.6.Slowly press X button until the 3 first LED are illuminated (paper,toner,light)Note:normaly this will require you to press the X button 11 to 13 times depending on the options and features installed.7. Press and hold green button until all LED flasch or strobe from left to right then relese the button.wait until this process stops with the same pattern as step 6.8.Press and hold X until the light pappern return to the pattern of four LED in theHome position.9.Turn the printer OFF.10.Turn the printer On.Note:if on a DHCP network, wait 30 seconds to see if the DHCP server/router sends out an IP adress to the device.11.Press green button to print a setting pages and observe that all the TCP/IP settings have been reset.12.Reconfigure the device using DHCP.Auto IP(zero configuration) or the IP Setup Utility.
This is my solution to the problem.//Oaklunde
Make sure you are using the correct IP address, If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section. To make sure you may also reset the NVRAM of your printer. To see instructions on how reset NVRAM you may click on the link http://bit.ly/p7ixP6 Once you get the correct IP address, please do the following steps Open the printer
Open the printer's web page or embedded web server.
Click on Configuration or Settings.
Click on the Network/Ports.
Click on TCP/IP.
Place on checkmark next to Enable DHCP.
Place a checkmark next to Enable AutoIP.
Scroll down to the bottom of the page and click Submit.
Power the printer off and on and wait a moment for the printer to pick up an IP address from the DHCP server.
For additional assistance, please contact Lexmark Technical Support.
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
This procedure requires that the printer to be communicating on the network. A temporary IP address may have to be set on the device to perform this procedure. If further assistance is needed, please contact Lexmark Technical Support.
1. Open the printer's web page or embedded web server.
2. Click on Configuration or Settings.
3. Click on the Network/Ports.
4. Click on TCP/IP.
5. Place on checkmark next to Enable DHCP.
6. Place a checkmark next to Enable AutoIP.
7. Scroll down to the bottom of the page and click Submit.
I tried a lot of procedures before this and none of them worked, this procedure works to reset the IP address. Cisco is correct that in step 3 you turn the printer on and you need to press the Continue button to initiate the sequence. Also, in step 6, for me, it was the paper and arrow lights flashing that did the reset.
