Question about Xymogen Pregnone Plus Topical Cream 2 oz
I am 64 years old and have been using Pregnone Plus for about 3 months now. My problem is that I am having "hot flashes". I apply the Pregnone Plus each morning and within an hour after application I experience hot flashes. I have never had hot flashes before, when I was going through menopause I had night sweats, but never hot flashes. My vaginal dryness is better, but I'm wondering if it is worth it...
Batteries failing
one would certainly think the batteries are replaceable .
Mar 19, 2015 | Panasonic Lands Phones
Tip
Tips on Is Shelf Life for Makeup
Every woman we know has a pile of makeup in her drawer that she "sometimes" uses. Translation: Never uses, but keeps just in case she finally learns how to properly apply blue eyeshadow.<br /><br />Beauty products do have a shelf life, however, and chances are that blue eyeshadow with the glimmery bits that you bought a couple years ago (for Halloween?) has long expired. Here's a quick guide on the shelf lives of typical beauty products. We've listed them in alphabetical order. Oh, and just one quick little "PS": Please keep in mind that these are estimates, no matter what anyone tells you, it's unlikely you'll go blind from using 2-year-old mascara.<br />&bull;Concealer Up to 12 months.<br /><br />&bull;Powder 2 years.<br /><br />&bull;Cream & gel cleansers 1 year.<br /><br />&bull;Pencil eye liner Should be sharpened regularly. Will last up to 3 years.<br /><br />&bull;Eyeshadow Will also last up to 3 years. Extra tip: A dark eyeshadow can double as eyeliner, in fact, most makeup artists swear by eyeshadow used as eyeliner. You'll need a super-flat eyeliner brush for this (MAC, Sephora and Aveda have great brushes). Get the brush a little damp and dab in dark eyeshadow (black, brown or deep jewel-tones work great). Wiggle the brush into your lash line focusing on the space between your lashes, then sweep the color just above your lash line.<br /><br />&bull;Brushes Wash every 2-3 months in a mild detergent.<br /><br />&bull;Sponges Wash weekly and discard monthly.<br /><br />&bull;Foundation Check the ingredients: A water-based foundation will last up to 12 months, oil-based will last up to 18 months. You may find you need two different shades of foundation each year: One for summer when your skin is naturally darker and one for winter when you're lighter. Extra tip: If your water-based foundation dries out before it's expiration date, simply add a few drops of alcohol-free. toner
on Nov 22, 2010 | Health & Beauty
I have Equity Time Insta-Set Model 40018. I lost the directions about how to set it. How do I get the directions? Are they available online?
Model 40018: You do not need the 9-volt battery to operate this clock.
NO TIME DISPLAYED WHEN PLUGGED INTO AC POWER:
If the display is blank when plugged into the AC outlet, unplug from AC power and remove the Insta-Set battery (lithium button cell), then plug into AC power again and manually set the Time and Date.
  • HOUR: Press and hold the DST SET button for 7 seconds until the 12:00 flashes. Use the PLUS and MINUS buttons to set the Hour. Press and release the DST button to move to the Minutes.
  • MINUTES: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Minutes. Press and release the DST SET button to move to the Month.
  • MONTH:The Month will be flashing. Use the PLUS and MINUS buttons to set the Month. Press and release the DST SET button to move to the Date.
  • DATE: TheDate will be flashing. Use the PLUS and MINUS buttons to set the Date. Press and release the DST SET button to move to the Year.
  • YEAR: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Year. Press and release the DST SET button to secure the setting in the memory.
After completing the manual set for time and date, insert a fresh Insta-Set button cell battery and the settings will automatically be stored in the clock.
Jan 31, 2015 | Audio Players & Recorders
Tom sat nav
You will probably find that your internal BATTERY is now well past "its useful lifetime" [around 2 -3 years plus]. The same thing [and symptoms] happened with my 10 year old TOMTOM OneXL.
I was quoted $80.00 [by TT here in Australia] to possibly fix it + the cost of the battery ???
SO I purchased a new TT Via 280 with LIFE-TIME FREE MAPS for just over AU $240.00 ... Works GREAT and better maps as well !!!
Nov 18, 2013 | GPS
I'm using Windows 7 64 bit & I can't Install "Bitware plus 4.0" in my computer. I see this message after starting Install: Title is: Unsupported 16-bit Application Message is: " The...
any 16 nit or 32 bit is not compatable with 64-bit operating system but yes they do make a 64 bit version of that software make sure your downloading the right version
Apr 01, 2011 | Computer Associates BitWare Plus 4.0 Full...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Model 31981B Replaced AAA battery's and now it is 3 hours behind
PROGRAM MENU: b> TIME ZONE: Use a pencil or paperclip togently press and release the TIME ZONE button one time. Press and release the PLUS button to choosefrom: PST= Pacific Time MST= Mountain Time CST= Central Time EST= Eastern Time Press and release the SET button to return to a normaldisplay. DAYLIGHT SAVING INDICATOR: The DST indicator isdefaulted to the ON position. If your area does not observe DST please removethe battery cover on the back of the station and move the DST switch to the OFFposition. SET CALENDAR, TIME, 12/24HR & F/C: Press and release the SET button once toenter the program menu. NOTE:Holding a button will move the digits faster. YEAR: The Year will be flashing. Use the PLUS or MINUSbutton to set the Year. Press and release the SET button one time. MONTH/DATE: The Month and Date will beflashing. Use the PLUS or MINUS button to set the Month and Date. Press andrelease the SET button one time. HOUR/MINUTES: The Hour and Minutes will beflashing. Use the PLUS or MINUS button to set the Hour and Minutes. Press andrelease the SET button one time. 12/24-HOUR TIME: 12Hr will be flashing. Use thePLUS or MINUS button to switch to 24-Hour time. Press and release the SETbutton one time. FAHRENHEIT/CELSIUS: The Temperature will beflashing. Use the PLUS or MINUS button to switch from F to C.
Dec 06, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
Warranty Validation
Usually you get 12 months, but sometimes up yo 3 years, plus they are usually quoted as lasting for a certain amount of hours.
Here is the web support page
http://www.seagate.com/www/en-us/products/desktops/barracuda_hard_drives#tTabContentOverview
Jul 22, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I have 2 clocks (model 40009,40010)that have inaccurate time
I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
Thanks.
Oct 24, 2009 | Equity Time USA 30731 LED Digital Electric...
I have a electric whirlpool 50 gal. energy saver water heater that is 3 months old. It keeps shutting off so i called whirlpool and sears came out and replaced the energy smart box on top. now it is...
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Jun 25, 2009 | Water Heaters
Xymogen Pregnone Plus Topical Cream 2 oz Logo
42 people viewed this question
Top Xymogen Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Xymogen Health and Beauty Expert? Answer questions, earn points and help others
