Kwikset 909  909-L03 Lifetime Polished Brass Smart Code SmartCode Signature Logo
Posted on Jul 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green light keeps blinking even after changing batteries
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on Jul 21, 2011
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489051
Points
1500
I can't help you directly, but I can direct you to Kwikset's customer service contacts. I'm sure they can assist you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
There is an 800 number to call listed here.
Light on Segway ninebot charger keeps blinking green.
A blinking green light on a Segway Ninebot charger typically indicates that the charger is properly connected and charging the device, but the battery is not yet fully charged. Once the battery is fully charged, the light should turn solid green. If the light continues to blink green and the battery does not charge, it could be an issue with the charger or the battery. Try using a different charger or testing the charger on another device to see if it is working properly. If the issue persists, contact Segway Ninebot customer service for further assistance.
Jan 13, 2023 • Cameras
1helpful
3answers
Why does the monitor's red and green light keeps blinking
Unplug, let it sit for a minute and plug back in. Ours does that when power is interrupted.
2answers
Light turns green but door won't open
Hi! I am trying to open this lock with my code, but it won’t open. It keeps blinking green. I didn’t change the code and I know that the red light was coming on for a few days. I think it’s the battery but any tips?
Nikon D40 green light flashing even when off
Sorry to hear this. Dropping something on concrete creates a high G force. Can you make sure the battery is fully charged before you put it in. If you have a good battery and all it does is blink something must have been broken. I think a D40 is a rather old camera too. Sorry I do not think I can help you. In most times a LED green blinking means it is charging. When carrying a camera you should wrap the strap around your wrist. If you do it correctly if you drop your camera it will not hit the ground. It is best to keep it from dropping on the ground.
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
1helpful
Sidekick Display Issues!
The trackball will blink green when the sidekick is in sleep mode, to let you know that it is still on just saving battery. I personally think it gets pretty annoying after awhile.. Also if it blinks blue while in sleep mode it means you have a new text, email, alert, etc. The only time the trackball doesnt blink green is when you are using it. Hope this helped!
24helpful
3answers
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Top Kwikset Locks & Locksmithing Experts
vince
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
