Olympus VN-2100PC Digital Voice Recorder Logo
Posted on Jul 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I reformated my Laptop and changed my OS from Vista to Windows 7. My VN2100PC software or program was perfectly working before but now neither I have driver CD to install nor I can find any on the internet. Please help.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Olympus Master 102,366 Answers
  • Posted on Aug 05, 2011
Olympus Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442199
Points
622693
Http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270&os=w
Need compleet software en drivers for Olympus vn2100pc to work on windows 7 ultimate 32bit
See this page of downloads for your vn-2100pc. Notice there is only for 7 64-bit:
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1270&os=w
However, on this page (under the heading "Which Computer Operating Systems Support the VN-2100pc?") is info for running in 7 32-bit. It says, "After downloading and installing Digital Wave Player v2.1.4, the recorder and software can also be used with 32-bit versions of Windows Vista and Windows 7." Go here:
http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1270
Good luck.
tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
Update driver for Olympus digital recorder Vn2100pc
You may download the latest Olympus software for the VN-2100PC here.
I am unable to run my ADAM software..it ran earlier but now doesn't run..i uninstalled the program, then installed it again..it won't accept my key, which came with the book..please help..i have windows 7
A.D.A.M. Interactive Anatomy 4, refer LINK
This program does not work with Windows 7 or MAC OSx
OS supported:
OS Specifications:
WINDOWS (DVD)
  • Microsoft® Windows® 2000, XP, Vista 32, Vista 64
  • Color display at 800 x 600 resolution
  • Pentium® 800 MHz or higher processor speed
Hope it helps.
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
2answers
Is there any other OS that is compatible with windows 7? All of my software is for my Vista. Is ther anything else I can do to make my OS more compatible?
Programs released before the market release of Windows 7 are most likely XP and Vista compatible only. What I recommend is to check the websites of those programs for available updates or upgrades. Newer versions of software are Windows 7 compatible.
12helpful
12answers
1helpful
4answers
I forgot the hdd password or , most likey my
Here is a tutorial showing you how to reset acer password: http://data-recovery-reviews.net/reset-password-on-acer-laptop.html
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
