SOURCE: The air purifier is blowing black soot.
the fine carbon are leaking , to reduce clinging black soot clean w/vacuum cleaner if that cabon dust it will not stuck within air purifier machine
SOURCE: air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
SOURCE: kenmore air purifier- model 85500
Press and hold down the off-timer button and the function button together for about 5 seconds and the replace air filter light will go off.
SOURCE: Filter Queen Air Purifier
you can call 1.866.660.0612 Fm Air Inc a Filter Queen distributor will be happy to assist you.
SOURCE: how to put together living air alpine bora III air purifier?
Hi Tlwynn,
The grid part of the screen should face the fan. The O3 produced by the cold-plasma discharge is what attacks the odors, and you want the fan to blow it out of the machine.
Make sure the spring-steel contacts are touching metal on both sides of the plate.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
