This error means there is an issue with with the heating portion of the dryer. Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
The element should be between 10 and 50 ohms if it's good. The thermistor should be around 10,000 ohms at room temperature and if both check good, replace the control board.
Hope this helps.
