MTX JackHammer JH600 Car Audio Amplifier Logo
Posted on Jul 20, 2011
Yellow light flashing on mtx jh600 amp - MTX JackHammer JH600 Car Audio Amplifier
4 Related Answers
Anonymous
  • 13 Answers
  • Posted on Oct 17, 2008
SOURCE: Amp Problems
Unplug the stereo input signal from the amp. If the amp does not do it with the wires unplugged, you may have a problem with the radio sending too much voltage to the input of your amp causing it to go into protect mode. If it continues it is in your power source to the units. Let me know and I'll see what Ii can do. Hope this helps...
Anonymous
  • 298 Answers
  • Posted on Jun 04, 2009
SOURCE: my MTX thunder 502x was working fine and know the
Could be a blown speaker/sub or a wire is crossed in the sub enclosure.
Anonymous
  • 5 Answers
  • Posted on Aug 10, 2009
SOURCE: mtx jh600 feed back in subs light on amp the bolt is blinking
check that the ground wire is bolted tightly to the chassis of the vehicle.
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Dec 28, 2010
SOURCE: i have a mtx jh600
You probably did not wire it proper..Keep in mind that you have to wire 3 lines for it ..the - and 2 + one for the main line and one for the remote activation ...and if you want to be powered it up and down when you insert and remove the key ..you have to wire the remote from a + connected to the ignition ...Usually it does have a + line that only has power when the key is inserted..under the main console...just check with a measurement device ..and see which wire has power on it when you switch the key ...and connect the remote on wire to it ..
The main power can be placed directly on the battery with a much thicker line ..and even insert a fuse on it ..
My mtx jh600 has 60 volts at output.Why?
any dc voltage at amp output is a sign this is blown. the problem is on the output transistors and can only be fixed by a technician
1helpful
My MTX JH600 works intermittently. I don't hear the fans coming on at all and the amp doesn't seem to get hot. Even at low power the amp will turn off all of a sudden and then boom back on after...
One of my friends had a amp like that , i looked at it an the inside of speaker box wires was touching , if thats not it then check ur power an ground , power wire must be the same size ground an if ur ground is not grounded good then u will get the cuting out .
Amp not working blue light is on?
You more than likely have subwoofer(s) wired too low for the amp. It's only stable down to 2 Ohms. You should rewire the sub(s) so that the amp will "see" a 4 or 2 Ohm load.
1helpful
It wont turn on, it give me a flashing light on the flash sign..
please run a thicker power and ground if u have already check ur fuse on the power make sure its a big enough amp fuse for the amp
Mtx jh600 feed back in subs light on amp the bolt is blinking
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
