Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
Anonymous Posted on Jul 20, 2011
Appears to run fine. but everything thawed. black canister at bottom (with coper wires from it) is hot to the touch. approx 3 years old
Mark Harnett
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Jul 20, 2011
Mark Harnett
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
25826
Points
370
Compressor is supposed to be hot... your problem may be that the unit is stuck on defrost cycle... The defrost timer should be behind the kick panel and have a dial type adjustment on it.... find it and try to turn it just a touch. It may come on but you will need to replace it if it does
Testimonial: "will try this. thanks so much!"
  • Anonymous Jul 20, 2011
    no dial adjustment behind kickpanel. is there another location?
  • Mark Harnett Jul 20, 2011
    theres a hole on the bottom where you can access a screw that will allow you to check and see if the defroster is working put a screw driver in the hole and turn it clock wise till you here it click and then listen for the unit to start defrosting cycle you'll hear a hissing like sound if its working if not you'll need a new defrosting unit
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
1helpful
Amana 20 - 20 years old. Freezer thawing - refreezing. Fan running very hot in the compressor arae at the bottom. Drip pan full of water - never saw that before.
IT SOUNDS LIKE YOU HAVE DEFINITE ISSUE WITH YOUR COMPRESSOR, IT MAY BE CONSTANTLY RUNNING OR RUNNING TOO OFTEN, THIS WOULD CAUSE THE LARGE AMOUNT OF HEAT COMING FORM THE BOTTOM. IF YOUR COMPRESSOR IS RUNNING TOO MUCH YOU WILL ALSO GET AN EXCESS AMOUNT OF WATER EVAPORATING DUE TO CONDENSATION ON THE EVAPORATOR COILS THEREFORE FILLING UP YOUR DRAIN PAN THAT MUCH QUICKER. YOUR FRIDGES COMPRESSOR MAY BE ON THE WAY OUT BUT YOUR FRIDGE SOUNDS LIKE IT'S WORKING THE WAY IT SHOULD BE.HOPE THIS HELPS
THANKS
Freezer froze on top thawing on bottom
Dispose of the unit and buy a new one. If it leaked the refrigerant out you have to fix the leak before charging it again. The chances of finding the leak are slim.
3helpful
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Condenser runs continuousley and is very hot
Don't know what kinda freezer this is? Commercial? Look for dirty condenser coils/ fins. Be sure air can circulate around condenser. Possibly low on refrigerant (freon). Need more info for more detail solutions.
Nov 15, 2008 • Freezers
1helpful
4helpful
4answers
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
