Locks & Locksmithing Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't open my safe. how can i know the combination of my safe. it is a normal safe.
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Jul 20, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
959871
Points
10121
Sorry, but you can't, That's why it's called a "safe".
If you lose the keys or the combination then the safe must be cut or drilled open. Some specialist locksmiths may be able to pick the lock or crack the combination, but it usually takes so long and costs so much that destructive entry proves to be cheaper. Many safes also have unpickable locks and uncrackable combinations anyway.
How do I change the safe's combination?
with door open, remove panel on back of door. remove the nut holding the three wheels in place and mark original location and then relocate the pin on back wheel. Reinstall nut. test visually to make sure you know the correct combination and be able to open it without watching the wheels in the door before closing and latching it again.
Got old honeywell safe No:HWF19004340, no key and don't know combination. Can it be opened?
contact a locksmith for the answer to your problem All safes can be opened by professional trades people.
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Have older sentry combination safe, i have combination but don't know procedure to open
left right left right 4,3,2,1 start from zero, count the first time the number passing
I have a Sentry Safe MSW3517 and can't remember
Not possible only u can do it with the dustruction of the combination lock pad.U ever register this safe?Yes?U can call the company up they'll tell u ur combination,because it a requirement,when u register it or they'll sent some one out for there master secret combination they get it open for u.
2helpful
3answers
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
2answers
I can't open my sentry mso100 safe. I think it. may have been compromised. I'm 99% sure i am using the right combination. Anything I can do?
Hi, well i see this type of thing with safes, frequently here in Fixya, and there is really NO way to do anything, I mean they are a safe and are designed to NOT be defeated. The ONLY thing that I know of to resolve the issue is to contact the manufacturer, and provide proof of ownership, and they will show you how and what to do to open that safe up.
21helpful
3answers
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
