Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
Posted on Aug 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence problem Hello, I'm having the same convergence problem , can't flash focus the problem away and can't manually make any adjustments. The picture has double images in the corners or red/green halos around the image. I can you explain how I can repair the convergence board?
Anonymous
Level 3:
  • Sony Master 5,138 Answers
  • Posted on Jun 26, 2011
Anonymous
Sony Master
Level 3:
Answers
5138
Questions
5
Helped
1004515
Points
13534
Replace both STK ICs they are Big Black ICs and will have Part Number on them,example STK392-110 .You will also need to check the pico Fuses in front and back of ICs they will look like resistors but will be Yellow or Green 5amps-7amp pico fuses. Mats Electronics has Parts 1-800-628-1118
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 19, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2014
Points
9
Replace the convergance ic chip on the board below the crt of whtever color is not working
How do I manually adjust the convergence on a Sony KP-61s70? It is equipped with "Flash Focus" that is not adjusting the convergence
Projection cabinets will generally have 3 adjusters under a panel behind the speaker grill or inside the back through a
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
I have a KDP51ws550 tv that has convergence problems. Flash focus would not work and neither would manual convergence. I replaced the both convergence ICs and checked the pico fuses, turned the unit back...
Check your soldering. Check the vertical power board on the far left when looking from the back. It has fuses on it as well.
Depending on quality of STK chips, they could have been bad or failed right away. Best things is to look at the schematic, verify what colors you can move and see which STK chip is not functioning.
If both chips are not function after replacement, likely a fuse. Be sure to verify the resistors next to the STK chips.
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
2helpful
Hello, my tv looks 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
I have a sony 60 inc rear projection lcd. the tv turns on ok, however, the picture and sound goes off and then comes on again. this happens every 15 minutes or so.
hello do these checks first Adjust the Picture setting in the Video menu (see page 49).
❏ Adjust the Brightness setting in the Video menu (see page 49).
❏ Check antenna/cable connections.
❏ Adjust the convergence again using FLASH FOCUS (see “Adjusting the
Convergence Automatically – FLASH FOCUS™ –” on page 33). if this don't work get back to me and we'll try somethink else thanks
shaun
Apex GB43HD10 Convergence
  • Screen looks 3D
How do you adjust the fine grain convergence on an hitachi 53hdx01b?
Your problem description is not clear.May be you have convergence problem with your unit.
Press flash Focus button on the control panel of the unit.If the flash focus complete one full cycle there is no problem with convergence amp.
Inorder to adjust convergence you need to enter the unit into service menu.
Good Luck
Dals123
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
