Bosch WFVC6450UC Front Load Stacked Washer / Dryer Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E-27 blinking - Bosch WFVC6450UC Front Load Stacked Washer / Dryer
  • Richard Roth
    Richard Roth Oct 14, 2012
    Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock. he E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
  • Richard Roth
    I have a little better instructions here http://appliancecafe.com/phpbb/viewtopic...
Richard Roth
Level 3:
Top Expert:
  • Bosch Master 9,472 Answers
  • Posted on Jul 20, 2011
Richard Roth
Bosch Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628840
Points
28464
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
  • Anonymous Oct 13, 2012
    No, turning off the power to the washer doen't clear the code. The very simple fix is to leave the washer in the error (blinking) state for about 3 minutes and it will clear itself. I was advised by Bosch "customer service" to call a repair technition. Don't do that. This is a very simple fix - save the money and hassle of a repair call. That is nothing but a racket. The Bosch customer service person should have given me the very simple procedure to clear the code over the phone.
  • Anonymous Mar 25, 2013
    Thanks for the tip...this worked perfectly...fixed the problem just as you said...thanks!!!
My 1994 27" sont KV27S10 blinks on and off. Any solutions? Advice?
How many times do these blinks occurs at one time switch ON? Count it. The blinks are fault indications, and are called blinking codes. If you wish to know more about these blinking codes, check the this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
1helpful
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
My 27" wega was making a crackling noise when I turned it on. Last time I turned it on it made a pop and went to standby, it blinks three times, pauses then blinks again clicks and blinks four times.
pls. check your tv mains plugh is luss canaction
if not then
probulum is in side tv set so pls. dont.use tv again and cont.nearest tv tech.and solve this problum. becous cracking noise is dengered for your tv.set
* you dont. open tv back cover it your self.becous in side tv set very high voltage.
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
6helpful
4answers
Manual for Panasonic CF-27 Toughbook
Web Site
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Donot enter model# in first slot.
Enter Computers in second
Enter Toughbook in third
Select CF-27E
Everythink is there, two pages.
Manual isn't much use.
1helpful
Sony kv-27s42 no picture no sound can here relay click
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Dan
1helpful
No sound or picture just blinking green light
That sounds like a power supply Issue, Unless you have the full service INfo and proper equipment its best to call a repair tech for your model as an isolation transformer is needed to saefly diagnose the power supplies.
2answers
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
