How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Testimonial: "Thank you. It does spray thinner normally...I guess I just didn't add enough thinner to the paint, I'll get a larger nozzle too."
Paint may be too thick, also there is a filter inside the cup it may be clogged with laquer. You may possibly take the filter in the cup out and get more flow.
