Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
Posted on Jul 20, 2011
How to dismantle the oven door to clean the inside of the glass of frigidaire gallery CGES387AB4
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jul 22, 2008
SOURCE: Clean Oven Door Glass
It is much more complicated than that. There are usually more screws once you take out the first 5. There are a total of 3 panes of glass inside the door. If you are very careful to note how the door comes apart once you've removed the screws, then you will be able to do this yourself. Just be aware that this is going to be more complicated than it looks. Lay the door on your counter or floor with the outside of the door up. Take out all the screws around the outer egde of the door. Lift by the handle and turn the top half of the door over so the handle side is on your counter. You will see 2 panes of glass held by the same bracket on each side. You only need to take one of the brackets off and remove both pieces of glass. Now you can clean the inner most piece of glass. Then clean the 2 you removed and put them back. Now reasssemble the door in the reverse steps. Make sure that all insulation and seals are back in place.
Anonymous
  • 833 Answers
  • Posted on Nov 20, 2007
SOURCE: GE oven door
First, determine what this gook is. If it is grayish, it is ash and can be removed with a rag and plain water. You'll always find ash as a byproduct of the cleaning. If it seems to be oven grease and is located in the gasket or gasket area ONLY, get some WD 40 and spray it on the gunk. Let it loosen up and remove it with a rag. You may need multiple applications. If possible, follow up with a soap solution to remove as much of the WD 40 residue as possible. Note, this may cause some smoking when the oven is next cleaned. Be sure to ventilate the area well while using this or any other solvent. Do not use the solvent on glass, it may discolor when heated. Use a standard glass blue liquid glass cleaner or water. If the glass won't clean easily, you may use a WET mild abrasive pad or steel wool VERY gently...so as not to scratch the glass. Follow up with a dampened rag. Anything you leave on the glass will be baked on...so make it clean! You may also use this procedure in the gasket area on the porcelain. Porcelain is a glass-based paint. It should not be scratched. Be patient.
Be aware that if you take door apart that the door is counter balanced. Removing a significant amount of weight by taking off pieces of the assembly may cause it to slam closed. Each of the two thicknesses of glass are mounted separately. Usually, there are some kind of clips holding the glass. Note that there is often fragile insulation inside the door. Avoid touching it or breathing in any dust it may emit. You may need a second pair of hands to align the door front and the bolt holes when re-assembling.
In the future, do not wait too long between cleanings. Use a rag to remove heavy spillage as soon as you find it, don't wait for a cleaning cycle. If your oven is very dirty, use a 3 hour setting or longer to finish the job if you have goo left in your oven after the cycle.
Bob
Anonymous
  • Posted on Mar 18, 2008
Take the door off.
Lay it on a flat surface-front down.
Remove six screws- 2 holding handle and 4 a bottom.
Carefully remove top part door assembly from front cover.
Clean glass.
Reverse the process to reassemble.
Anonymous
  • 150 Answers
  • Posted on Apr 22, 2008
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Anonymous
  • Posted on Feb 15, 2009
SOURCE: gravy spilled between the glass on the oven door
how to take off the front door
Where can I get my Frigidaire double oven door glass repaired
You can buy the new glass yourself and do it, as an easy task. Or you just called a Figidaire service tech. You will need the model number and you don't tell us :>D
https://www.google.com/search?q=frigidaire+gallery+oven+door+glass+replacement
videos for inner and outer door glass
How can I remove the vapor barrier on my Panasonic Inverter Microwave to clean the glass!
Inner layer of a microwave door is part of the metal cage that keeps the microwave energy inside and prevents potentially dangerous energy leaks.
To clean the inside of the glass the door will need to be dismantled - some doors dismantle easily and some don't and sometimes the door must be removed in order to dismantle...
Some doors remove easily and some don't...
It is very important the door is reassembled correctly and then tested for energy leakage.
Frigidaire double wall oven clean between the glass
Remove door off the hinges. Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
5helpful
2answers
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
3answers
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Clean glass range door
Hello. I recommend a product called Cameo. Cameo is a non abrasive cleanser actually designed for the new type enameled sinks recomended by American Standard. AND iit works great on oven door glass. You can get it at Walmart. Very inexpensive and works great on all kinds of surfaces that may be hard to clean but you don't want a harsh cleaner that might damage the surface or scratch. Has a very light to almost none scent. Very good for cleaning the oven both inside and out. Doesn't have the chemical smell left by some cleaners that can be intensified by heat.
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 • Ovens
5helpful
Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Fridgidare gallery oven malfunction?
A spill dripped down on the inside of the glass of the oven door. How can it be cleaned and what would it cost?
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
