Question about Dehumidifiers
One, no manual for Classic ECD40E made by Woods. Two, recieved from a friend, someone tried to fix, need wiring diagram to make sure wires are in correct postion. Reason: Compressor turns on for a few minutes then shuts off. Stat set on max and fan on high. Wondering if neutral and hot wires changed on relay on compressor?
First, tell me the serial number and will get back to you if I find something in my system.
Posted on Jun 17, 2013
SOURCE:
  • 184 Answers
SOURCE: Whirlpool 50 pint dehumidifier
the problem just might be that your are trying to use this unit at a time of season that is cold weather. there is no humidity in the air so the unit is cycling on and off .there by the noise you hear. dehums work best when the temp is 65 degrees or higher and the humidity level is 60% or higher. and that means outside. in order to have humidity the water has to be heated up to the point that it starts to evaporate.
Posted on Mar 28, 2008
SOURCE: DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Posted on May 10, 2008
SOURCE: compressor runs, overheats and shuts down..fan does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at http://www.appliancefactoryparts.com/. I ordered one; we'll see what happens.
Posted on Apr 27, 2009
  • 12 Answers
SOURCE: Fan runs, all controls work compressor does not run.
It sounds as if the unit has lost it's refrigerant charge. Take to small appliance repair for confirmation, but it probably leaked out.
Posted on Jun 29, 2009
james3751
  • 614 Answers
SOURCE: Humidifier compressor does not stay on more than 1-2 minutes
Sounds like bad relay on compressor or bad compressor. There is only so far you can go yourself without knowledge in electrical and AC units. Suggest you call a service tech or if you can take it to service cemter near you. Russ
Posted on Jul 24, 2009
Need wiring diagram
Here's a link to the Owners and Service Manuals for Kenmore Dehumidifiers. Simply find your Model Number and click on it. You will be able to download and print the manual.
http://www.appliancefactoryparts.com/dehumidifiers/helpcenter/ownersmanuals/kenmore/
Hope this helps you.
May 26, 2011 | Maytag M7DH45B2A Dehumidifier
Manual ed50
Hi. Not sure if you were ever able to obtain a manual, but I found one online as I am trying frantically to find a new blower motor for my Wood's Frostguard ED50. The link I found the manual at is www.woods.se The dehumidifiers are apparently from Canada.
Jul 13, 2010 | Woods WD25G Dehumidifier
I need a wiring diagram for an Ebac 880e dehumidifier
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 29, 2010 | Ebac HD880 Dehumidifier
The bearing in the fan is shot. where can I get a new fan?
Find someone who sells this make for a direct replacement. Otherwise ww grainger and many other hvac repair companys with carry a replacement. Get the hp,voltage,amps and direction it turns. measure it to make sure it fits and mounts the same. Also some replacement motors has 2 wires for the capacitor so get new one and don't try to wire it to old capacitor. Most are duel porpose on new units and will run fan and compressor. Some new motors have the option to us only one brown wire for duel cap but make sure you use the correct brown wire one is solid and one with have a white stripe if it will work both ways. Also make sure Cap MFD matches new motor.
Jul 04, 2009 | Haier Dehumidifiers
Hook up my 2 sub and my 2 amp
wire the subs at 2 ohm each. red to red and black to black and then to the amp. if thay are a dual 4 ohm sub. dual 2 ohms will need to be wired red to black on one coil and the other conected to the amp.
Apr 09, 2009 | Danby DDR601 Dehumidifier
Location of Maytag M7DH45B2A motor fuse
I'm fixing one of these too. Take the top off (follow the AC cord) and the fuse is on the PCB.
I am also looking for a better wiring diagram - the control panel on mine does not light up.
Aug 21, 2008 | Maytag M7DH45B2A Dehumidifier
NO POWER TO MY DEHUMIDIFIER
I took my dehumidifier apart and I found why the unit no longer would start.
First, there is a fuse inside the metal compartment that houses the control circuit board.
However, the fuse was not blown. Instead I found the relay that controls the compressor,
(circuit diagram calls it RY-COMP) was not functioning and was left in the open position.
The relay must switch the compressor on/off based on humidity, full water hopper, and
maybe other factors like temperature.
The RY-COMP is a large black plastic component on the circuit board with two
wires (blue and black) connected at the top. I tested the contacts and they remained
open when starting up the dehumidifier. Doing a small bit of rewiring so that the blue and black wire
were connected and also wired to RY-COMP terminal 3, the dehumidifier came back to life.
However, this is good for proving what broke but without an electronic control to cycle the
unit on and off and to halt when the water hopper is full it's not a valuable alternative and
it risks a burnout of the compressor from constant use.
I think the RY-COMP relay is a solid state relay which could have gone bad from a spike
in voltage when plugging the unit in or cycling on/off.
I certainly don't want to buy another unit where the circuitry is not robust enough to survive
plugging in every couple weeks. I was thinking I could try replacing the relay with a magnet relay which would probably survive spikes much better.
Mar 03, 2008 | Goldstar DH304 Dehumidifier
DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
Sep 04, 2007 | Dehumidifiers
Dehumidifiers Logo
114 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
